I need to replace the burner control of my electric Jenn Air downdraft range, model S156. How do I remove the front panel for access. Please help!
Originally Posted by: guy39  I need to replace the burner control of my electric Jenn Air downdraft range, model S156. How do I remove the front panel for access. Please help! I believe if you open the oven door then look up where the control is you'll see some screws that hold the control in place. With those removed the panel should pivot up, and come loose. Make sure you remove power first.
