dsteverson
#1 Posted : Friday, September 22, 2017 4:08:02 AM(UTC)
dsteverson
The auger motor stopped working (no noise at all) on our ice maker. The auger itself is free turning. I have done the following:
Switched dip switch on the door with the one on the water dispenser (water still works).
Bought a replacement auger motor (******** - supposedly new)
Bought a replacement control panel - new
None of the above steps has made any difference. I have tried to find a components diagram to see if there are any parts between motor and control panel I may have missed.
I would appreciate any suggestions. Thank you.
dsteverson
#2 Posted : Friday, September 22, 2017 7:48:55 AM(UTC)
dsteverson
PS I can turn the auger motor using a socket, but it has a lot of resistance. This is true for old and supposedly new motor. Does that sound correct? Thanks
Maytag Auger Motor Kepts Running & Won't Stop (Refrigerator & Freezer Repair)
by abacon11 10/21/2016 7:10:58 PM(UTC)
by Tom_Va123 10/3/2012 6:48:46 PM(UTC)
