dzapper
#1 Posted : Tuesday, September 5, 2017 1:14:47 AM(UTC)
dzapper
I went to put a load of clothes in the washer tonight and it wouldn't fill. I messed with the control knob and found that it would in fact spin and it does add water during the spin cycle. Messing with the temp control had no effect as did blowing on the pressure tube, which was clear. Valves, timer, and drive motor have all been replaced in the past.
brobriffin
#2 Posted : Tuesday, September 5, 2017 3:58:05 AM(UTC)
brobriffin
Man
United States
How long ago did you replace those items and was it for this same reason?
When you say i does add water during spin cycle do you mean it will fill up for rinse or is it only spraying water during final spin?
Will it fill with water when you set it to rinse cycle?
Does anything change if you set the timer to one of the other cycles like delicates etc?
When you are messing with the temp control (switching from hot to warm to cold wash) have you tried doing so while the unit is turned on?
dzapper
#3 Posted : Tuesday, September 5, 2017 11:48:26 AM(UTC)
dzapper
Several years and no it was for different problems.
Just spraying during final rinse
No
No
Yes
dzapper
#4 Posted : Tuesday, September 5, 2017 1:50:55 PM(UTC)
dzapper
Welp when the spousal unit finally awakened from her slumber she informed me that it has been doing that and jiggling the control knob usually fixes it. Lo and behold upon opening the cover with the power still on the unit started working. When I put the cover down it stopped again. Apparently the plug to the timer control has just enough play in it to lose continuity on some circuits while still being securely clipped together. I'm not sure what the remedy is but at least I know the problem.
brobriffin
#5 Posted : Wednesday, September 6, 2017 7:51:22 AM(UTC)
brobriffin
Man
United States
Try unplugging the connector from the timer and clean the contacts on the timer and connector. Use something similar to what I show in the attached picture.
brobriffin attached the following image(s):
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Washer only spins, and has to be unplugged to stop. (Washer Repair)
by metalheadbrian 5/16/2017 5:49:13 AM(UTC)
Cabrio Washer only spins on High Speed (Washer Repair)
by Mikehonz 5/24/2015 8:29:48 AM(UTC)
Maytag washer only spins, but it's trying! (Washer Repair)
by RedRyder89 10/30/2013 7:38:17 PM(UTC)
Magtag washer only spins (Washer Repair)
by taxesbytina 4/28/2013 4:05:40 PM(UTC)
Front load washer only spins one direction (Washer Repair)
by e5dave5 4/23/2013 3:53:22 PM(UTC)
Kenmore Washer Only Spins By Itself on Final Spin Cycle (Washer Repair)
by Wayjer 12/12/2012 11:42:34 AM(UTC)
Whirlpool washer only spins with nothing inside (Washer Repair)
by George.gill 11/27/2012 7:02:28 AM(UTC)
Washer only spins (Washer Repair)
by Tooks38 10/23/2012 6:29:42 AM(UTC)
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode (Washer Repair)
by adava 10/1/2012 3:51:51 PM(UTC)
Washer only spins and drains (Washer Repair)
by jperrot 5/3/2012 3:04:38 PM(UTC)
Washer only spins! (Washer Repair)
by Toney7 3/24/2012 10:36:07 AM(UTC)
whirlpool washer only spins (Washer Repair)
by karyna 6/14/2011 2:15:02 PM(UTC)
Washer only spins before rinse not after full cycle (Washer Repair)
by jws058 3/19/2011 11:30:09 AM(UTC)
kenmore washer only spins on two of three cycles (Washer Repair)
by herman 11/5/2009 2:23:28 PM(UTC)
