mandrix
#1 Posted : Monday, September 4, 2017 8:40:16 AM(UTC)
mandrix
Rank:: Member
Hello everyone, first post.
My washer door would not open after a load was washed, so I removed toe plate and manually opened door.
Now washer won't start so I pulled codes and the most recent was F5E2 Door Lock Error.
Before I order a door lock I wanted to know: where's the ccu and how do I access it (check wiring) , and: is there a guide for replacing door lock?
Thanks.
mandrix
#2 Posted : Monday, September 4, 2017 10:38:55 AM(UTC)
mandrix
Rank:: Member
Thanks.
OK after making the post I found the video's.
But I still need to know how to access the ccu although I'm increasingly leaning toward the door switch as the problem. Never hurts to trace wires though.
mandrix
#3 Posted : Monday, September 4, 2017 10:58:33 AM(UTC)
mandrix
Rank:: Member
OK I found some youtube video's, I know where the ccu is and how to access it. I'll just check connectors and if all looks good I'll likely order the door latch.
