Hello everyone, first post. My washer door would not open after a load was washed, so I removed toe plate and manually opened door. Now washer won't start so I pulled codes and the most recent was F5E2 Door Lock Error. Before I order a door lock I wanted to know: where's the ccu and how do I access it (check wiring) , and: is there a guide for replacing door lock? Thanks.
Originally Posted by: mandrix  Hello everyone, first post. My washer door would not open after a load was washed, so I removed toe plate and manually opened door. Now washer won't start so I pulled codes and the most recent was F5E2 Door Lock Error. Before I order a door lock I wanted to know: where's the ccu and how do I access it (check wiring) , and: is there a guide for replacing door lock? Thanks. OK after making the post I found the video's. But I still need to know how to access the ccu although I'm increasingly leaning toward the door switch as the problem. Never hurts to trace wires though.
OK I found some youtube video's, I know where the ccu is and how to access it. I'll just check connectors and if all looks good I'll likely order the door latch.
