My girlfriend's Kenmore dryer won't power up. Nothing happens when I press the start button. I did the following tests: -Continuity test on the start button (ok) -Voltage test on the power outlet (240v) -Continuity test that failed on the buzzer, I changed it, same result. I guess a continuity test on a buzzer is invalid -When I open the door, the light does not turn on even though the bulb and the light socket passed their continuity tests -Continuity test on the thermal fuse (ok) -Continuity test on the heating element (ok)
I'm at a loss. Could it be the timer? Is there any way the power wouldn't reach the dryer? Could it be a faulty cable, and if so, how can I test it?
Thanks in advance
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
In order to better assist you please double check the model number and post it. The one you've listed isn't showing up on our list.
