JulienGS
#1 Posted : Friday, September 1, 2017 1:10:14 PM(UTC)
JulienGS
My girlfriend's Kenmore dryer won't power up. Nothing happens when I press the start button. I did the following tests:
-Continuity test on the start button (ok)
-Voltage test on the power outlet (240v)
-Continuity test that failed on the buzzer, I changed it, same result. I guess a continuity test on a buzzer is invalid
-When I open the door, the light does not turn on even though the bulb and the light socket passed their continuity tests
-Continuity test on the thermal fuse (ok)
-Continuity test on the heating element (ok)
I'm at a loss. Could it be the timer? Is there any way the power wouldn't reach the dryer? Could it be a faulty cable, and if so, how can I test it?
Thanks in advance
brobriffin
#2 Posted : Thursday, September 7, 2017 4:32:25 AM(UTC)
brobriffin
Man
United States
In order to better assist you please double check the model number and post it. The one you've listed isn't showing up on our list.
