Rob Krueger
#1 Posted : Tuesday, November 3, 2009 1:48:22 PM(UTC)
Rob Krueger
oven stopped working, no clock or funtions work. oven light does work when you open door. breaker is ok
#2 Posted : Tuesday, November 3, 2009 4:35:37 PM(UTC)
Groups ready for retrieval: Senior Expert
Replacement parts for aoes3030e models | AppliancePartsPros.com
Here is a tech sheet and a manual
http://www.servicematters.com/m...ibrary/docs/16021875.pdf
http://www.servicematters.com/m...ibrary/docs/16021876.pdf
First thing I would do is shut the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Next measure the voltage
L1 to L2, should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
The oven lights on this unit get power from L2
While the board uses the L1 side
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
Vintage Wall Oven SIZES (General Talk)
by sabfre 12/21/2023 8:52:31 AM(UTC)
GE Monogram Electric Wall Oven Model No. Z EK938SM1SS (Oven Repair (including Ranges and Cooktops))
by Govtman 11/14/2023 7:24:46 PM(UTC)
Kenmoore wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 6/23/2023 1:46:47 PM(UTC)
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Gaffers and Sattler wall oven 1970-1980 models (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 2:45:52 PM(UTC)
Determining voltage for 1960s GE-J-720 wall oven install (Oven Repair (including Ranges and Cooktops))
by Austo1989 2/22/2023 4:33:49 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Old GE Double Wall Oven - Top isn't working (Oven Repair (including Ranges and Cooktops))
by Doubletheoven 11/25/2022 5:19:46 AM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
