windsong3099
#1 Posted : Thursday, August 10, 2017 12:07:16 PM(UTC)
windsong3099
Has been working fine for a couple of years, had to turn off the water main to do work in the bath room, once the water was turned back on the dishwasher hasn't worked.
When starting the cycle, the drain works, the water come out of the left side wall and fills up to the mesh piece in the center. Instead of starting the cycle to spin the arms it just makes a high pitched noise for that part of the cycle, then it drains without problem.
Researching, it sounds like it could be the impeller or the circulation motor.
Any and all help would be appreciated.
Kenmore dishwasher not washing! (Dishwasher Repair)
by joolee123 2/22/2010 7:27:18 AM(UTC)
