joolee123
#1 Posted : Monday, February 22, 2010 7:27:18 AM(UTC)
joolee123
My dishwasher has started making a loud buzzing noise and doesnt seem to have good flow of water. Some water definately does spray inside..but dishes don't get clean and soap never fully dissolves....../ I can't live without my dishwasher!! Help!!! Any ideas or suggestions would be wonderful! Thanks!UserPostedImage
ps. the buzzing noise occurs when i normally would hear water sloshing around.....but no water can be heard
Qtip
#2 Posted : Monday, February 22, 2010 7:56:01 PM(UTC)
Qtip
if the dishwasher is underfilling you will want to replace the water valve but if the water level is normal check to make sure the impeller isnt clogged
#3 Posted : Wednesday, February 24, 2010 4:25:37 AM(UTC)
Here is the tech sheet which should be helpful
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
If the unit is filling with water then it sounds like either the impeller is jammed or the pump is toast.
