I received part #1317632 to replace door switch part #131269400. I will need to change terminal endings of wires to make this part work. My wiring diagram is missing. Can you tell me which colored wires go where?
I've done hundreds of these locks and never needed to change any wiring harness terminals... are you sure you got right part? Frigidaire has been using this lock with the same 3 plugs for decades. There is a kit that includes concrete weight and pump harness to use normal lock on really old machines.
Dear Drew, apparently they don't make the old door lock anymore (#131269400--I think I have a 1999 machine) and the new lock (#1317632) has the three plug in areas you mentioned. The wiring harness on my maching has only one plug and four separate wires. I just can't figure out how to make them work.
My machine model number is FWT449GFS1 and it pumps and drains but will not spin
