cjohns62
#1 Posted : Thursday, July 27, 2017 10:06:28 AM(UTC)
cjohns62
I received part #1317632 to replace door switch part #131269400. I will need to change terminal endings of wires to make this part work. My wiring diagram is missing. Can you tell me which colored wires go where?
PNWDrew
#2 Posted : Thursday, July 27, 2017 9:00:34 PM(UTC)
PNWDrew
I've done hundreds of these locks and never needed to change any wiring harness terminals... are you sure you got right part? Frigidaire has been using this lock with the same 3 plugs for decades.
There is a kit that includes concrete weight and pump harness to use normal lock on really old machines.
cjohns62
#3 Posted : Sunday, July 30, 2017 6:36:33 AM(UTC)
cjohns62
Dear Drew, apparently they don't make the old door lock anymore (#131269400--I think I have a 1999 machine) and the new lock (#1317632) has the three plug in areas you mentioned. The wiring harness on my maching has only one plug and four separate wires. I just can't figure out how to make them work.
My machine model number is FWT449GFS1 and it pumps and drains but will not spin
cjohns62
#4 Posted : Sunday, July 30, 2017 6:36:36 AM(UTC)
cjohns62
PNWDrew
#5 Posted : Sunday, July 30, 2017 2:30:21 PM(UTC)
PNWDrew
I recieved part #131763202 to replace door switch part #131269400.AppliancePartsPros.com
See if that answer below pic makes sense... it doesn't do a good job at all to me and omits that fact that there are wiring changes that also should be done for this retrofit. Could you rig it up? Maybe but having a door successfully lock will help you avoid repeated floods.
If not this kit is I think what was sold to make new switch fit old machines
Frigidaire 137523400 Door Switch/lock Kit - AppliancePartsPros.com
I would advise using the kit, despite the increased cost.
