aycarumba22
#1 Posted : Tuesday, June 20, 2017 5:34:31 PM(UTC)
aycarumba22
The dryer takes 3 cycles to dry. Why?
brobriffin
#2 Posted : Friday, June 23, 2017 6:16:42 AM(UTC)
brobriffin
Man
United States
Many times when a dryer will start and run while the start is pushed but stop the moment you let go is due to a bad centrifugal switch on the motor.
watch this video for more info how this switch works
https://www.youtube.com/watch?v=CaaqRXQERVc
Bill gives a good explanation of how it works. You needn't do this elaborate of a test. But just know that if the wiring is intact you will need to replace the motor due to the contacts inside the switch being burnt or the switch lever/mechanism being broken.
GE Dryer will not stay running when start button released (Dryer Repair)
by danielwik 7/26/2014 4:43:31 AM(UTC)
