Hello, My Maytag Fridge was operating great until I changed the water filter. Immediately after changing it, the dispenser began making loud groaning sounds and the water would pulsate out when in use. I replaced the filter with another new filter and the same thing occurs. I removed the water filter and inserted the filter bypass plug and everything is fine -- the water pressure seems to have increased as well. Would you please help? I've read through many of the posts on this subject, but cannot seem to find one with the same issue.
Thanks very much.
Debbie
