jpcoseno
#1 Posted : Monday, May 29, 2017 9:18:30 AM(UTC)
jpcoseno
Hi All,
I have a KItchenaid model kudk02crbs2 dishwasher.
It works fine in rinse mode and will drain water. However in Normal Cycle it shuts down after a while leaving water in the tub. No power is on the electrical box which has the garbage disposal and the dishwasher on it. The breaker isn't tripped.
I can go to the breaker and turn it off and on and everything turns back on and the dishwasher will drain the water.
I replaced the breaker thinking that was the issue and it worked for about 1 1/2 months with no issues and now it started up again.
I took pics of the wiring of the electrical box and the dishwasher if this helps.
I appreciate any advice and help.
thanks
jpcoseno attached the following image(s):
