AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Kichenaid Dishwasher- Shuts down halfway thru Normal Cycle
Hi All, I have a KItchenaid model kudk02crbs2 dishwasher. It works fine in rinse mode and will drain water. However in Normal Cycle it shuts down after a while leaving water in the tub. No power is on the electrical box which has the garbage disposal and the dishwasher on it. The breaker isn't tripped. I can go to the breaker and turn it off and on and everything turns back on and the dishwasher will drain the water. I replaced the breaker thinking that was the issue and it worked for about 1 1/2 months with no issues and now it started up again. I took pics of the wiring of the electrical box and the dishwasher if this helps. I appreciate any advice and help. thanks jpcoseno attached the following image(s):
Dishwasher Repair
