richard203
#1 Posted : Tuesday, May 16, 2017 2:28:17 PM(UTC)
richard203
hi I got a Samsung rs265tdrs for 3 years and I tried to hired a tech to fix the problem but they give up and refund my money so I just want to give it another shot on fixing this. the tech replaced the heating element and deiced the fidge everything works until 3 month it build ice only on the left side of the food section, now I keep deicing the fidge every couple month or when im free any help?
richard203
#2 Posted : Thursday, May 18, 2017 5:13:12 PM(UTC)
richard203
I ordered motor fan since top section temperatures at 65-68 degree and middle section at 48-50 degree testing the bottom draw section to see if its warmer or colder. any suggestion?
richard203
#3 Posted : Friday, May 19, 2017 5:31:40 PM(UTC)
richard203
oky checked the temp on the bottom drawer they are at the temperature that I set the fidge to which is 36 degree. recheck the top now its around 50-55 degree.
richard203
#4 Posted : Tuesday, May 23, 2017 6:20:05 PM(UTC)
richard203
is it normal to have condensation in the fridge?
richard203
#5 Posted : Thursday, June 1, 2017 9:02:52 PM(UTC)
richard203
is this forum any active? don't know if I should keep posting here and getting no answer
richard203
#6 Posted : Monday, June 5, 2017 3:34:55 PM(UTC)
richard203
hope some1 here will come help. just did the self diag and it flashes 5 E and 22 E. any help?
richard203
#7 Posted : Tuesday, June 13, 2017 9:00:00 PM(UTC)
richard203
since 22 e is motor fan, should I replace the motor evap and the wire?
richard203
#8 Posted : Tuesday, June 20, 2017 6:07:01 PM(UTC)
richard203
k just want to know why my front both corner is leaking from the bottom?
