hi I got a Samsung rs265tdrs for 3 years and I tried to hired a tech to fix the problem but they give up and refund my money so I just want to give it another shot on fixing this. the tech replaced the heating element and deiced the fidge everything works until 3 month it build ice only on the left side of the food section, now I keep deicing the fidge every couple month or when im free any help?
I ordered motor fan since top section temperatures at 65-68 degree and middle section at 48-50 degree testing the bottom draw section to see if its warmer or colder. any suggestion?
oky checked the temp on the bottom drawer they are at the temperature that I set the fidge to which is 36 degree. recheck the top now its around 50-55 degree.
is it normal to have condensation in the fridge?
is this forum any active? don't know if I should keep posting here and getting no answer
hope some1 here will come help. just did the self diag and it flashes 5 E and 22 E. any help?
since 22 e is motor fan, should I replace the motor evap and the wire?
k just want to know why my front both corner is leaking from the bottom?
