PATRIOT2017
#1 Posted : Saturday, April 1, 2017 7:32:25 PM(UTC)
PATRIOT2017
Whirlpool top loading washer LSR7233EQ0 timer stops at the same location at start of soak cycle and will not advance. But get this . . . a simple nudge on the front of the machine and timer starts and completes all remaining cycles. On top of this, this problem is intermittent. Go figure!
:mad::confused::mad::confused:
PATRIOT2017
#2 Posted : Tuesday, April 4, 2017 10:39:43 AM(UTC)
PATRIOT2017
Lid switch actuator had worn over the last 20+ years.
Simply threaded a SS screw to bring it back to its former glory.
Works fine and it's adjustable to boot.
Just love it when a plan comes together!
:D:D:D:D:D
PATRIOT2017 attached the following image(s):
