Whirlpool top loading washer LSR7233EQ0 timer stops at the same location at start of soak cycle and will not advance. But get this . . . a simple nudge on the front of the machine and timer starts and completes all remaining cycles. On top of this, this problem is intermittent. Go figure! :mad::confused::mad::confused:
Lid switch actuator had worn over the last 20+ years. Simply threaded a SS screw to bring it back to its former glory. Works fine and it's adjustable to boot. Just love it when a plan comes together! :D:D:D:D:D PATRIOT2017 attached the following image(s):
