I put a new transmission in this machine however in the process I knocked the spring tensioner out of the notch where it goes hoping for help because where I put it, it is trying to burn the belt off when trying to spin need a belt route or tensioner spring placement.
Originally Posted by: Jason H  I put a new transmission in this machine however in the process I knocked the spring tensioner out of the notch where it goes hoping for help because where I put it, it is trying to burn the belt off when trying to spin need a belt route or tensioner spring placement. Thank You so much , i really appriciate it very much!
