Jason H
#1 Posted : Monday, November 2, 2009 2:06:11 PM(UTC)
Jason H
I put a new transmission in this machine however in the process I knocked the spring tensioner out of the notch where it goes hoping for help because where I put it, it is trying to burn the belt off when trying to spin need a belt route or tensioner spring placement.
sidfink43
#2 Posted : Wednesday, November 4, 2009 10:07:46 AM(UTC)
sidfink43
There should be seveal notches in which you can place the spring to adjust the tension, but you may need to go ahead and replace it.
Here is a service manual which may help.
http://frigidaireservicetips.com/pdfs/489_5.pdf
Jason H
#3 Posted : Wednesday, November 4, 2009 4:26:56 PM(UTC)
Jason H
Thank You so much , i really appriciate it very much!
