Water comes in but not enough not raise float before it shuts off. Does not go into wash cycle.
Does float switch control fill valve, or is there also a time limit?
Does float switch need to be closed for circulation pump to engage?
Thanks for any help.
Wow, what an amazingly useless forum this is.
Found info I needed on You Tuibe.
Recommend others try that first.
