haze
#1 Posted : Monday, March 27, 2017 2:21:19 PM(UTC)
haze
Water comes in but not enough not raise float before it shuts off. Does not go into wash cycle.
Does float switch control fill valve, or is there also a time limit?
Does float switch need to be closed for circulation pump to engage?
Thanks for any help.
haze
#2 Posted : Friday, March 31, 2017 2:21:12 PM(UTC)
haze
Wow, what an amazingly useless forum this is.
Found info I needed on You Tuibe.
Recommend others try that first.
