gciccol
#1 Posted : Saturday, March 18, 2017 3:53:07 PM(UTC)
gciccol
My dishwasher doesn't fully drain out the water from the tub. There is about 1/4 inch of water around the back of the tub at the end of the wash cycle.
Repair Steps.
1. I removed the filter frame, piston and nut assembly,sump cover and sump cap in the rear of the tub. There was nothing blocking them. I used a shop vac to suck out all the water and anything down in the sump area.
2. The Piston and Nut Assembly looked a little worn so I replaced it with a new one.
3. The Drain Solenoid arm moves freely and the piston slides up/down fine. I watched it engage during a test cycle where the piston was pushed down for about 30 seconds as the tub was draining. I also pulled it out of the unit to test it for resistance. I showed 37 ohms of resistance which my research says is correct for a good solenoid. I reinstalled it on the washer.
4. I removed the Check Valve & Body Assembly. The check valve looked a little worn so I replaced it with a new unit.
5. I checked the drain line where it connects into the garbage disposal and it was clear. I forgot to check the line coming out of the bottom of the drain pump before I reinstalled the washer back into the cabinet.
6. I did not test the drain pump as I don't know how. I do see the drain solenoid engaging and hear the pump pushing water as I saw the drain line moving back and forth so it seems like the drain pump is fine.
Does anyone know of another test I could be doing?
Is there a way to test the pump/motor assembly?
Is there a test to check if the control board is just shutting off the drain pump too soon at the end of the cycle?
The only thing I have left to replace is the complete pump/motor assembly and I hate to spend $128 on it and find it doesn't fix my problem.
Any assistance would be greatly appreciated. Thank You
Dishwasher not fully draining (Dishwasher Repair)
by gciccol 6/27/2012 2:07:54 PM(UTC)
by JandLKay 8/9/2010 2:18:42 PM(UTC)
Brand New KitchenAid Dishwasher Not Fully Draining (Dishwasher Repair)
by lmkelly1 10/21/2008 9:52:13 AM(UTC)
