sshipman350
#1 Posted : Friday, February 24, 2017 8:39:10 AM(UTC)
sshipman350
I have a whirlpool fridge that has a bad thermostat. Part number 2315562. I have had this part on backorder for 1 month and was told today that the manufacturer will not be shipping these until May 1st. With that said I was hoping to make a temporary fix. My question is.... Can I just take an available more common t-stat (2198202) and utilize it in the correct t-stats location?
I do realize that the cosmetics wont match. I do realize that this may have to just be temporarily plastic tied to some sort of fastener. But I also realize that a t-stats primary job is to just connect and regulate two wires touching each other. Any reason this wont work? They are both 120/240volts! Many thanks in avance!
Do Have a defrost thermostat problem (Refrigerator & Freezer Repair)
by radarguy101 11/10/2011 4:33:18 PM(UTC)
Defrost/thermostat problems after running awhile? (Refrigerator & Freezer Repair)
by InAZ 4/24/2010 3:37:35 AM(UTC)
Thermostat problems (Dryer Repair)
by randywapp 12/4/2009 4:16:42 PM(UTC)
Thermostat problem with mini fridge (Refrigerator & Freezer Repair)
by Edogyip 11/3/2009 8:59:00 AM(UTC)
Thermostat problem? (Refrigerator & Freezer Repair)
by Troubleshooter 2/26/2009 11:23:21 AM(UTC)
Thermostat Problem (Oven Repair (including Ranges and Cooktops))
by MDR 2/8/2009 4:50:08 AM(UTC)
