walter22
#1 Posted : Monday, November 2, 2009 8:29:39 AM(UTC)
walter22
I have a whirlpool duet washer that turns on and then the control panel goes blank. I then unplug it for a while and sometimes it will com back on and it will work for that wash cycle. Other times it goes dead the door says locked and I have to unlock it by hand. I was told it is the (ccu) that is causing the problem. Can you tell me if this is true before I put more money into and expensive washer.:mad:
sidfink43
#2 Posted : Wednesday, November 4, 2009 9:24:17 AM(UTC)
sidfink43
It is somewhat difficult to diagnose a problem with the CCU if the CCU itself is bad because the company has programmed diagnostics and error codes into the CCU, but if the CCU is defective, well, you get the picture.
There should be tech notes under the front cover which will show you how to put the machine in diagnostic mode.
See if you can do that and get better clarity on your problem. At the end of the day you may just have to replace the board on spec. Welcome to the world of appliance microprocessor controls.
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
