Occasionally the display lights on the door panel would go out and the come right back on. Yesterday they stayed out the entire day causing the temp on the fridge and freezer to rise. Today it came back on and temp is back to normal. I think I should replace one of the electronic control boards,but I am not sure which one? There is one in the back (wpw10310240). And there is one in the front (w10740217). Can anyone help? I'm assuming this will happen again
Originally Posted by: Dlep ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Occasionally the display lights on the door panel would go out and the come right back on. Yesterday they stayed out the entire day causing the temp on the fridge and freezer to rise. Today it came back on and temp is back to normal. I think I should replace one of the electronic control boards,but I am not sure which one? There is one in the back (wpw10310240). And there is one in the front (w10740217). Can anyone help? I'm assuming this will happen again I replaced the main board and a week later the front panel started do the same as yours. I was hoping someone would have answered your question.
