Hello, I'm having problems with a Maytag refrigerator. It will run fine for 4 to 5 days then stop cooling. I'll unplug it, usually over night then plug it back in and it'll run fine for another 4 to 5 days. Have cleaned the coil, fans are running, changed the starter relay and capacitor. Checked ohms at compressor last night, in the range of 10, 6, 4. When it stops cooling the compressor is hot to the touch. Not sure which route to take now any help would be greatly appreciated.
Stan
