danjng
#1 Posted : Thursday, December 29, 2016 9:39:25 PM(UTC)
danjng
So I recently did a thermal sensor (the one in the control panel) reset. I had scoured the forums and Internet and discovered that some sensors can be reset by bringing it's temperature down to 32 degrees. We'll, that surprisingly worked and things were good again... Except for one thing. While the heating elements worked, the fan wasn't running when I used the microwave. Am I in any danger at all? Any ideas about why it's dead? Is this the fan in van get to through the panel or do I need to remove the entire oven/microwave?
Here's a link to the oven/microwave: https://www.ajmadison.com/cgi-bin/ajmadison/JTP90.html
As a side note, there seem to be like 10 different sensors and I am not sure which one to pick up as a replacement. I can't find one that looks exactly like the one in mine. It says nt101 and kie whatever that means.
Thoughts and ideas are welcome! Any help is greatly appreciated!
