My combo oven was showing error code F6 E0 on both upper and lower. After power cycling the lower oven cleared and is working fine but the upper oven returned with the error and will not operate. Ive tried to put the unit in diagnostic mode, off, off start, a bunch of times but nothing happens. Ive tried it on both upper and lower controls and still nothing. any advice would be much appreciated. Thanks
The troubleshooting is not going to be simple. Follow the instructions from the attached tech sheet for this error code. Post the results. Here are the break down diagrams for the oven/microwave combo Model KEMS308SSS02
