hyman
#1 Posted : Monday, December 5, 2016 7:25:00 PM(UTC)
hyman
My combo oven was showing error code F6 E0 on both upper and lower. After power cycling the lower oven cleared and is working fine but the upper oven returned with the error and will not operate. Ive tried to put the unit in diagnostic mode, off, off start, a bunch of times but nothing happens. Ive tried it on both upper and lower controls and still nothing. any advice would be much appreciated. Thanks
#2 Posted : Tuesday, December 6, 2016 6:51:16 PM(UTC)
The troubleshooting is not going to be simple. Follow the instructions from the attached tech sheet for this error code. Post the results.
Here are the break down diagrams for the oven/microwave combo Model KEMS308SSS02
File Attachment(s):
Tech Sheet - W10220956 - KEMS308SSS02.2-7.pdf (1,950kb) downloaded 6 time(s).
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Fisher & Paykel DishDrawer DD60 - Fault Code Diagnostics (Dishwasher Repair)
by Rehud 12/18/2021 6:34:25 AM(UTC)
Don't trust the JAZZ board diagnostics!! (Refrigerator & Freezer Repair)
by Stahlmaster 9/8/2021 3:22:06 PM(UTC)
Fridge warm, freezer is fine - Can it be the dampers if they pass the diagnostics? (Refrigerator & Freezer Repair)
by ocjk 6/23/2021 7:39:39 PM(UTC)
Can I trust this Fridge? Did running the diagnostics actually fix it? (Refrigerator & Freezer Repair)
by netpog 12/13/2020 4:07:12 PM(UTC)
Whirlpool Gold Diagnostics WSF26C3EXW01 (Refrigerator & Freezer Repair)
by MikeBab 3/14/2020 8:12:09 PM(UTC)
Maytag MRT311FFFZ00 thermistor chart & diagnostics mode (Refrigerator & Freezer Repair)
by scottaobe 2/1/2019 8:35:11 AM(UTC)
Self diagnostics (Refrigerator & Freezer Repair)
by paulv 9/28/2016 3:16:43 AM(UTC)
Whirlpool Dryer Overheat. Lots of diagnostics and parts replaced (Dryer Repair)
by Mike6158 7/1/2016 4:00:23 PM(UTC)
Whirlpool coin washer - diagnostics? stopped in cycle (Washer Repair)
by g20zoom 11/23/2015 8:56:46 PM(UTC)
dryer diagnostics (Dryer Repair)
by ScottKrueger 6/18/2015 2:46:04 PM(UTC)
need. diagnostics (Washer Repair)
by Lindy Hugh 3/2/2015 10:29:54 AM(UTC)
Amana Defrost Diagnostics - 1 problem or 2? (Refrigerator & Freezer Repair)
by Urbo464 1/5/2014 3:10:41 PM(UTC)
Diagnostics won't finish (Dishwasher Repair)
by ericchristopher 11/16/2013 8:45:00 PM(UTC)
Cooling fan error code diagnostics (Oven Repair (including Ranges and Cooktops))
by jamie.rucker 10/19/2013 9:49:19 AM(UTC)
