StephenSanborn
#1 Posted : Wednesday, November 30, 2016 10:02:43 AM(UTC)
StephenSanborn
GE Monogram ZGU385LSM2SS gas cooktop.
Spark & LED indicators died at the same time.
Troubleshooting revealed primary on the internal power transformer failed open. Noted that all secondary windings are okay.
Replaced transformer, worked but only a short while, then transformer failed again with same symptoms. Primary failed open again, but again all secondarys are okay.
So before I put in another transformer, question is what else can be wrong? In particular does the dual transformer failures mean that the spark module itself is defective?
OldMadBrit
#2 Posted : Friday, November 10, 2017 2:54:01 PM(UTC)
OldMadBrit
Exactly the same here. Looked for a short down-line but cant find anything obvious.
