jhols
#1 Posted : Tuesday, November 29, 2016 11:02:21 AM(UTC)
jhols
My Dishwasher stopped working and I could smell some burning so I took the door off and found the attached.
The burned connectors on the left look bad. I'm assuming I will need a new control board, will I also need to replace the harness-type thing there?
Here are the images
Kitechnaid control board
Thanks in advance!
ThatGuy
#2 Posted : Tuesday, November 29, 2016 11:27:37 AM(UTC)
ThatGuy
Groups: Expert
United States
If you don't fix the wiring connector, it will burn up the same connection on your new board.
Electrical connections need to be clean and tight.
jhols
#3 Posted : Tuesday, November 29, 2016 11:58:27 AM(UTC)
jhols
Thanks for the reply. I'm also pretty curious why this would happen. In the first place.
I run the dishwasher and the disposal on a single 20a circuit. My electrician said that this wasn't a problem but I'm starting to question that.
KGSS9*** burned control board and other issues (Oven Repair (including Ranges and Cooktops))
by stevon 12/26/2022 4:01:28 PM(UTC)
dishwasher burned control board (Dishwasher Repair)
by firepiper 2/7/2010 12:12:18 PM(UTC)
