I have a kitchen aid dishwasher that does not dry the dishes after any cycle. Additionally it will not heat the water for high temperature settings. I have tested the heating element with an ohm meter and it tests ok. I have also tested the thermostat and it tests ok as well. (closed) Since kitchen aid does not supply a wiring diagram, I don't know if the next step is to replace the control board or the timer. Any help would be appreciated.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Thanks for the reply! I located the directions for accessing the diagnostics and was able to reset the electronic / computer control. It had set an error code for a draining problem. I assume it was an isolated event so after resetting I will run the dishwasher through a cycle and see if it dries the dishes. Will update forum. Thanks again for the reply.
