The ice chute door is not closing all the way causing ice build up on the inside chute of the ice maker. I replaced the solenoid, ice door assembly and spring. After replacing those it closes much better but still leaves 1/4 inch gap. Why would this be happening?! I checked the solenoid and it moves freely and there is nothing visibly blocking the door from closing. Help!
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Yes the spring is in correctly
Groups: Expert
Without seeing it, its hard to say whats gone wrong.
Try comparing your door assembly with the parts shown at 1:38 in the video.
Maybe you could take some detailed photos and post them.
