Maytag french door bottom freezer, icemaker is located in upper left side of refridgerator, ice maker is making ice but water is leaking into ice bin and freezing around auger causing it not to turn. could it be the dual water inlet valve and if so where is it located, thank you
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
