lkm
#1 Posted : Wednesday, October 19, 2016 6:14:32 AM(UTC)
lkm
Dryer operates normally for 1-3 minutes and then appears to slow down. Checked belt and it does not appear to be slipping. Heating element is working properly. No unusual noise detected.
brobriffin
#2 Posted : Wednesday, October 19, 2016 7:40:54 AM(UTC)
brobriffin
Man
United States
First thought
If it is your motor going bad this is an issue to resolve quickly. The motor also runs the fan that in turn moves the proper amount of air preventing the heating element from overheating. Have you noticed a buzzing or humming sound when you first try to start the motor?
Secondly
It may be an issue with the drum rollers and bearings seizing up. Try turning the drum by hand when you see it slow down and then try to turn it prior to starting a load when its cold. This might give an indication of the bearings or support roller seizing up.
lkm
#3 Posted : Friday, October 21, 2016 4:28:22 AM(UTC)
lkm
Brobiffin, thank you for your response. I have not noticed a buzzing or humming noise. As far as turning the drum is concerned, it does not appear to seize up.
brobriffin
#4 Posted : Sunday, October 30, 2016 10:13:26 AM(UTC)
brobriffin
Man
United States
Sorry late reply, just got back from vacation in the smokey mountains...
If you haven't done so I recommend replacing the motor. That buzzing / humming sound and then slowing down after a couple minutes seem to indicate a motor gone bad.
Here is the part you will need.
Whirlpool 279787 Dryer Drive Motor - AppliancePartsPros.com
Whirlpool duet washer front load (Washer Repair)
Belarus Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
