I believe it would fill up to the correct level, but it's not like I left the lid open to check it. I was just happy it was working at all.
But no, the last time I tried using it, turning the dial to another setting wouldn't make anything happen, it'd just sit there.
Maybe "control module" was the wrong choice of words, I was talking about the little circuit board with an arm sticking out of it that bolts onto the motor and plugs into the wiring harness.
I had the capacitor tested at my local hardware store months ago and it checked out, but I can always take it back and have them check it again. Is it possible that it's gone bad even if it's testing at the proper microfarads?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
If it tests out between 189-227 uF (microfarads) then it is not the issue. I would then suspect your motor is bad.
