3 Pages<123
Punisher Bass
#21 Posted : Tuesday, May 16, 2017 4:06:53 PM(UTC)
Punisher Bass
I believe it would fill up to the correct level, but it's not like I left the lid open to check it. I was just happy it was working at all.
But no, the last time I tried using it, turning the dial to another setting wouldn't make anything happen, it'd just sit there.
Maybe "control module" was the wrong choice of words, I was talking about the little circuit board with an arm sticking out of it that bolts onto the motor and plugs into the wiring harness.
I had the capacitor tested at my local hardware store months ago and it checked out, but I can always take it back and have them check it again. Is it possible that it's gone bad even if it's testing at the proper microfarads?
brobriffin
#22 Posted : Tuesday, May 16, 2017 4:23:14 PM(UTC)
brobriffin
Man
United States
If it tests out between 189-227 uF (microfarads) then it is not the issue.
I would then suspect your motor is bad.
Guest (5)
3 Pages<123
