Our Maytag dryer will turn on and we hear a "click" indicating (I think) that the door safety latch has engaged. We hit the start button, but nothing happens. I read online that this is a common problem and it is typically the fuse. A quick check with my multimeter for continuity showed that the thermal fuse was bad. I replaced it with a brand new one (tested it for continuity first to be sure) and I am still getting the same results. I also replaced the thermistor since I was right there...still not getting anything. Any more ideas on what to check?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
