Hello,
I have a double oven Kenmore Stove from the 90's, the door of the main oven has begun to not close completely and hang open about an inch.
For reference, the part number of the door hinges are 5303210232 & 5303210233 for left and right.
How do I go about fixing this?
Thanks for any help in advance!
If no one is really familiar with this kind of oven, perhaps someone might be able to point me towards a repair manual for these?
I'm unsure about how to adjust the hinges, they seem to be in rather difficult to access positions, the left hinge is between the small oven wall and large oven wall and the right hinge is between the large oven wall and exterior panel.
I don't know if I can get at the hinges from underneath the oven, or if I have to take the side panels off and remove the small left oven, which seems like a big job so I want to be sure before I try and do that.
Any help would be much appreciated!
