GE
kdanilson
#1 Posted : Wednesday, September 14, 2016 5:48:09 AM(UTC)
kdanilson
My Dryer recently quit working. I immediately noticed that the timer knob felt strange when I would turn it. It wasn't turning smooth and wouldn't stop in all locations but just jump to 2 or 3 locations. I ordered a new timer switch (PN#WE04X20416) and installed it and it fired right up and turning the knob felt normal again. I let it run for about a half hour before leaving the house and everything was fine. When I returned that evening the clothes that were in the dryer were dry so I assumed everything was good. The next morning I went to use the dryer this morning and I have the same issue with the timer knob feeling weird and the dryer wont turn on again. Need some help... I have to assume that there is something else that is going on that is causing the timer switch to fail? I got 1 load of clothes dried with my new $50 switch. Any help would be appreciated.
brobriffin
#2 Posted : Wednesday, September 14, 2016 11:39:25 AM(UTC)
brobriffin
Man
United States
Can you elaborate a little on when you say the timer won't stop in all locations? Do you mean when you turn it to a certain spot it will advance on its own to a different spot?
Does this same thing occur if you turn the dial to that spot with the door open?
I also imagine when you say it quit working that it won't start when you push the start button?
kdanilson
#3 Posted : Wednesday, September 14, 2016 3:00:31 PM(UTC)
kdanilson
Thanks for the response. Yes as you turn the timer switch it's motion isn't smooth and it will advance itself in certain areas. It does the same thing with the door open. After the initial load after replacing the switch It won't start when I push the start button.
brobriffin
#4 Posted : Wednesday, September 14, 2016 3:39:56 PM(UTC)
brobriffin
Man
United States
Apparently there is a short circuit somewhere. The timer motor should only run when the dryer is running and it shouldn't run when the door is open. Some further investigation on your part I'm afraid. Now it's very likely your old timer is good.
So do you happen to have the wiring schematic for you unit? Typically it is tucked away in the control head of the machine.
kdanilson
#5 Posted : Wednesday, September 14, 2016 6:13:06 PM(UTC)
kdanilson
Thanks for taking the time to help, I figured it out. I now feel pretty stupid for changing out the timer switch. It turns out the the turn knob was cracked where it slides on to the timer shaft. This was causing the knob to just spin without actually moving the timer shaft.
old kenmore fridge click (Refrigerator & Freezer Repair)
by rleescott 7/4/2024 7:07:45 AM(UTC)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
OLD FRIDGEDAIRE OVER & UNDER GLRT214RAW4 (Refrigerator & Freezer Repair)
by brou102 6/29/2024 10:51:20 AM(UTC)
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
Kenmore Fridge Supco (Refrigerator & Freezer Repair)
by Tony442 6/23/2024 8:34:01 PM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
True GDM-26-LD Display Fridge compressor issues (Refrigerator & Freezer Repair)
by KSlank76 6/22/2024 10:24:23 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
