Ive seen similar problems to mine but not quite the same here goes
Washer gets through wash n spin then stops at rinse cycle get a humming sound but no water. YET get water when i restart cycle Problem occurs mainly in hot weather normal water temp close to 80F in summer from mainline
Ive replaced timer, blown out vacuum fill, switched fill selinoids(reversed hot n cold). Suspect temp thermostat wants lower temp for rinse, should be cold water only. Can i bypass the temp controls? We only use cold water anyways
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
A better solution can be determined with a model number!
