Cjraymond
#1 Posted : Saturday, August 20, 2016 1:08:29 PM(UTC)
Cjraymond
Ive seen similar problems to mine but not quite the same here goes
Washer gets through wash n spin then stops at rinse cycle get a humming sound but no water. YET get water when i restart cycle Problem occurs mainly in hot weather normal water temp close to 80F in summer from mainline
Ive replaced timer, blown out vacuum fill, switched fill selinoids(reversed hot n cold).
Suspect temp thermostat wants lower temp for rinse, should be cold water only. Can i bypass the temp controls? We only use cold water anyways
brobriffin
#2 Posted : Monday, August 22, 2016 2:46:36 PM(UTC)
brobriffin
Man
United States
A better solution can be determined with a model number!
Bosch dishwasher mystery part (Dishwasher Repair)
by icemank 5/30/2016 9:33:05 AM(UTC)
Kenmore washer mystery leak (Washer Repair)
by 1967hammer 5/15/2010 4:33:03 PM(UTC)
clothes washer mystery vibration (Washer Repair)
by grunion 2/25/2008 11:45:53 AM(UTC)
