dishdr
#1 Posted : Thursday, August 18, 2016 7:50:35 AM(UTC)
dishdr
I am working on a DW that won't wash. It fills and seems to go into the wash cycle, but motor doesn't run. It does also drain out. I removed the motor to find that the impeller had spun off and was wedged inside housing. After reassembling, still won't run. I found the fuse that is soldered onto the electronic control board was blown. For diagnosis purposes, I jumped across it. With the motor connector unhooked, I have 117v at board pins. When I connect wires, voltage at pins drops to 87v. Motor still doesn't run. Could the motor if bad be dragging the volts down, or is the ECB bad. I have direct wired the motor and it does run. Any thoughts. Thank you for any input.
Dean Haustead
#2 Posted : Monday, August 22, 2016 10:19:09 PM(UTC)
Dean Haustead
My dishwasher seems to purpose usually. The dishes appear fresh, but the water from the previous cycle remains in after it has stopped. The water is clear. I have read the manual and rearrange the system some times. When I push the cancel button to flush out the remaining water in the morning, you can hear the water being pumped out, and it sounds like the pump is operational well.
