DCAJR1
#1 Posted : Wednesday, August 17, 2016 12:09:50 PM(UTC)
DCAJR1
washer stopped after cycle but won't spin or drain. Lid switch is intact, moves up and down and clicks when depressed with a screw driver. There is no motor sounds.
brobriffin
#2 Posted : Thursday, August 18, 2016 4:50:13 AM(UTC)
brobriffin
Man
United States
Try turning the dial back to wash and see if the machine will begin agitating again. If so, but the machine won't drain and spin, then although the switch feels and sounds like its working its probably not.......
That being the case here is your part number..
Whirlpool 285671 Lid Switch Assembly - AppliancePartsPros.com
