AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore wont spin or drain. no noise. Lid switch does click.
washer stopped after cycle but won't spin or drain. Lid switch is intact, moves up and down and clicks when depressed with a screw driver. There is no motor sounds.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Try turning the dial back to wash and see if the machine will begin agitating again. If so, but the machine won't drain and spin, then although the switch feels and sounds like its working its probably not....... That being the case here is your part number.. Whirlpool 285671 Lid Switch Assembly - AppliancePartsPros.com
Washer Repair
