Maytag Washer spraying oil under my washer. I have a Maytag mav9501eww top load washer that I just replaced the tub seal/spindle, bearing and 2 white gaskets which took care of my water leak. When I tested the washer in the garage I noticed oil being sprayed around the bottom of the washer on my floor. Looks like the oil is from the transmission/belt area. My question is 1.) did I not tighten one of the bolts enough 2.) does the spindle need to be torqued more 3.) do I need to change a transmission seal under my washer? 4.) can I still find a transmission seal for my model if that's the problem?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
