C78
#1 Posted : Monday, August 15, 2016 12:04:43 PM(UTC)
C78
Maytag Washer spraying oil under my washer.
I have a Maytag mav9501eww top load washer that I just replaced the tub seal/spindle, bearing and 2 white gaskets which took care of my water leak. When I tested the washer in the garage I noticed oil being sprayed around the bottom of the washer on my floor. Looks like the oil is from the transmission/belt area. My question is
1.) did I not tighten one of the bolts enough
2.) does the spindle need to be torqued more
3.) do I need to change a transmission seal under my washer?
4.) can I still find a transmission seal for my model if that's the problem?
brobriffin
#2 Posted : Thursday, August 18, 2016 5:06:40 AM(UTC)
brobriffin
Man
United States
Whirlpool 207843 Transmission Lower Lip Seal - AppliancePartsPros.com
Transmission bottom lip seal kit, instructions included.
